Hi.
as far as i can find out, this is part of the self diagnosing, fault finding system on newer scooters.
different number of flashes signifyiing different faults. i cannot find a specific manual for the rascal scooter, but on most scooters of this type 9 flashes is listed as "other internal fault, return to dealer for inspection"
this could cover absolutely anything. the only thing i can suggest, is that oyu check all of the electrical connections are clean and secure. make sure there is no obvious damage to any wiring, and that all of the control units, motor, and brake unit are clean and secure on the scooter.
there is very little else that a user can do to these scooters, other than returning it to the dealer for a full inspection.
dealers should be able to give you a free estimate of repair costs. and then it is up to you if you have it done or not. the only thing to be careful of, is that most dealers are just interested in selling new scooters, so they will try VERY hard to get you to buy another scooter rather than have your existing one repaired as they can make far more money this way. you will have to stand your ground to get a free estimate.
good luck.
hope this helps
DId you ever fix this problem as I have what seems to be the same?
