To delete a single entry from the call log, press CID/down. Use up/down to scroll to the desired entry and press MUTE/REMOVE. To delete all entries, press CID/down, then press and hold MUTE/REMOVE until it display "DELETE ALL?". Press MENU/SELECT.
To store a directory entry, Press MENU/SELECT twice to enter the DIRECTORY. Use up/down to reach "STORE" and then press MENU/SELECT. The screen displays "ENTER NUMBER". Use the keypad to enter the number and then press MENU/SELECT. The screen displays "ENTER NAME". Use the keypad to enter the characters and then press MENU/SELECT. The screen displays "STORED" and you'll hear a confirmation beep.
You should be able to download the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/85/UserManual/245/6041_Manual.pdf
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
