This V6 with carb starts and runs fine. Sometimes between cold and warm acts like it wants to die. And sometimes it does. Other times it it fully warmed up then acts like you turned the key off. Sometimes it does not want to start. Added Heet, replaced coil, checked ign module. Cap,rotor, wires, plugs appear to be Ok. Any thoughts?
Oh! and the choke is working fine.
No where is it?
Are you referring to the permanent magnet on the shaft? Can this go bad?
Thank you Thank you Thank you
Have you replaced the distributor stator? You say you checked the ignition module, I think you should have replaced it, I would suspect the module over the coil and the rest of the parts you replaced.
