SOURCE: Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
SOURCE: my nokia 3110c is not switching on
Check if battery on the phone depletes fast. If there's nothing wrong with the battery try poercycling the phone (turning phone off and removing battery from the back and insert battery after 1-2 mins). If the problem persist try master resetting the phone. Remember that by doing the master reset it will delete some of your saved info on the phone.
SOURCE: Need restriction code for my nokia 2330c. When I
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
