I just got a new classroom and the teacher before me had a canon i550 printer and didn't leave the manual...... I can't figure out where I shoud put the paper. Please help me!!
as for the settings........
Go to0 the start menu, select "printers and devices"
select your printer, select printer preferences,
and change the setting from the menus.
There ya go!..........Please remember to RATE ME. Thank You.
Had the same problem with my I550. Was going to buy a new printer
(I4000) since I could get one for about $30 more than the price of a
new print head. I like canon printers with the individual ink tanks and
have had no problems with the I550 for about three years.
Decided
to try moving the paper thickness lever back an forth a number of times
since some of the error messages indicated it could not determine the
setting of the paper thickness lever. I don't know how the printer
determines this switch setting but I thought if some contacts are
slightly oxidized that movement might break up some of the oxidation.
After operating the lever about a dozen times the printer started
working. Hope this will help.
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865) 1. Start with the printer OFF 2. Hold down RESUME and then hold down POWER 3. release RESUME 4. press RESUME twice, then release POWER 5. Let green light blink until printer is done moving print head. 6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter
