Expert
- Posted on Jun 22, 2011
Re: The mixer makes noise at stir speed. If I press down...
Hi,motor bearing usually worn out if you dont put grease on it.try also to check screws it might loosen up.Bearing might as well not contacted with the upper surface does it makes noise.Screw and bolts might as well loosen .Hope this helps.
