Hello, welcome to FixYa.
There is typically a drain filter in the pump as you know, however there should be a door lock release on Asko built machines...including the W600 series.
This is the typical procedure for machines of the past 10yrs. or so...
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Good luck.
Regards,
Macmarkus :)
Hello & Welcome to FixYa
F2 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F2. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
Hello &
Welcome to FixYa
the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the
other questions.
Kevin
Hello &
Welcome to FixYa
the unit is unable to drain then after 4 minutes it will display sud and then
other questions.
Kevin
