On many of the newer units you can have the option of the unit draining or not draining....
If the drain plug is not punched out then the water will build up and the fan will splash the water onto the condenser coil and cause evaporation that way....it is not necessary to drain them...just make sure they are tipped back in the window a bit so the water does not run inside...
Of course if you want to drain them you can look for the plug and punch it out allowing the water to run out... it is usually in either of the back bottom corners of the pan...
heatman101
N0 there is not drain hole. Newer A/C units throw the condensation water up to the hot condenser coils outside to help cool down the coils.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
This issue usually occurs due
Daniel
