Mitsubishi WS-65511 65" Rear Projection Television Logo
Anonymous Posted on Jun 21, 2011
Tv switch on and off when press power button - Mitsubishi WS-65511 65" Rear Projection Television
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Jun 21, 2011
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718609
Points
48227
IF power light comes on for a moment and then goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
  • 1 more comment
  • grhine750 Jul 22, 2011
    My problem is 2blinks then 4 blinks, please advise and Thank You !!!!!!
  • Jane Spence
    Jane Spence Nov 11, 2013
    I have 5 red blinks and 7 yellow
  • Dave McKenna
    Dave McKenna Feb 16, 2014
    My Mitsubishi WS-65511 keeps shutting off. I get the 22 error code when I press the menu and device button. I am getting a lack of continuity on picofuse F9A05. How do I fix this problem?
I have a 51inch LG TV and never had a problem I turned it off as normal and then tried to turn it on a while later and nothing I only got a red solid stand-by light it don't flash when press side buttons...
Try following the steps below.
Step 1
Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.
Step 2
Observe the Standby light if the remote control will not work. If the Standby light stays on, the television is in Standby mode. Press the power button on the television, then try to use the remote.
Step 3
Turn the Energy Saving Switch off, then press the power button. The Energy Saving Switch is located on the rear or side panel on most Sony model TVs. Refer to your TV user manual for the exact location of the switch.
1helpful
3answers
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
15helpful
2answers
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
21helpful
2answers
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
1helpful
How do i turn it on?
  • If you have the TV Code listing, first set up:
  • Slide the TV/WebTV switch to TV.
  • Find the brand of your TV
  • Press the Code Set button.
  • Use the Number buttons to enter the three-digit code for your brand of TV.
  • Press the return button.
  • Slide the TV/WebTV switch back to WebTV.
To see if the keyboard operates your TV, press the Power (TV) button. If the TV turns on or off, the Keyboard successfully operates the TV. Hope this helps.
TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
7helpful
Codes for Universal remote.
You have to perform a quick search (although it might not be that quick) for the code. Proceed as follows:
IMP: Switch on your TV set.
1. Press the SET button and hold.
2. While holding the SET button press the TV1 (or another TV/AUX button) and release both buttons.
3. Press the SET button again. The red light is now bleeping.
4. Press the POWER button repeatedly at 1 or 2 second interval until your TV switches off.
5 When the TV turns off press the TV1 button again and you are done.
Hope this helps.
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
7helpful
2answers
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
