Check that the exhaust air outlet hose (if fitted) is not obstructed or crushed. If not fitted, check that the exhaust air outlet is not blocked nor too close to anything which may impede the flow of exhaust air. Also check that the air inlets are not blocked.
Basically your machine "thinks" that it has an airflow obstruction, and usually that's caused by the filters. If that's not the case then you'll have to call in a repair technician to correctly diagnose the fault. The cause is then likely to be a simple failure of a switch or sensor and a relatively cheap and fast repair, especially if your machine is under warranty.
My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter
care light, so cleaned the filter and now the light comes on but nothing
happens. Any ideas? Thanks
