User I need code for newstar ntr b28z for my Sony tv
ChatGPT Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User need code for newstar ntr b28z
ChatGPT To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV. Press and hold the "TV" button on your Newstar remote until it blinks twice. Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step. Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code. Once you've found the correct code, press the "TV" button again to lock it in. If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
Turn on your Sony DVD player.
Locate the code for your Sony DVD player in the code list provided with the universal remote.
Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
Enter the code for your Sony DVD player using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
Turn on your Sony Bravia TV.
Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
Enter the code for your Sony Bravia TV using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
These are the universal setup codes for Sony brand TVs. If you want more codes and other details to different remote controls, check this link. Codes to check are: 0128 0013 0002 0071 0380
From your description the flyback transformer has failed causing the high voltage to load down, if the TV is 10 years old or more, consideration should be given investing in a new set.
I was unable to find the code for that specific cable box. The TV was no problem, And I couldn't find the combo code, but I have the Sony VHS code and DVD code. Maybe they'll work.
Sony TV: 002, 006, 071, 128
Sony VHS: 004, 099,128,139,140,141,147,154,155
Sony DVD: 009, 174
I hope this helps!
Press Code Search button Indicator light on.
Press TV button light blink.
Here some codes enter for Sony TV 002,218,099,166.
tries Every these codes the blink light should off.Off On button should work tv goes off or on .
that it u have it
