Televison & Video Logo
Posted on Aug 21, 2008
Orion tv stuck on aux without a remote
I have an orion tv, not sure wat kind and all that but i pressed somethin i guess and now its stuck on aux channel. i do not have a remote controll because i forgot it at my parents house and im hours away how do i get it back to tv mode???
A
Anonymous
Hi i dont have a remote to my orion 13in tv and some how dont know what i pushed but now its stuck on the aux mode and i can seem to get it off no matter what i press
Go to this link to match the MODEL NUMBER of your TV to the listings, then select you manual.
http://www.eserviceinfo.com/fulltext.php?search_ft=orion%2013%20inch
Try pressing menu, and using the volume up or down (might channel up or down) to scroll thru the choices.
1helpful
2answers
Orion TV 1933 stuck on AUX
I assume that pushing the channel up and channel down buttons does nothing. You could try unplugging it overnight and see if it's forgotten its settings come morning. But if that doesn't work, you're probably going to have to get a universal remote and program it to your TV. Quite a number of TVs (and DVD players and VCRs for that matter) no longer have a full set of controls on the TV. Some things just can't be done without the remote (a fact that really irritates me). -Dyllan
3answers
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
9helpful
3answers
Orion TV 1333 No remote can't get into Aux how do i do that manually?
not worth buying a remote, you can use an rf converter or what i did was use an old DirecTV remote as i have several. on DTV remote, set selector switch located at top of remote all the way to the right to tv. Then hold down the select and mute button at the same time until the green light blinks 2 times, then enter one of these codes until the power button turns on the tv. Codes are as follows
10236 10463 11463 10179 11911
11929. Also verify that the tv input button does activate the aux channel. I knew these old remotes would come in handy some day.
Orion TVDVD092, No Remote
did you find your remote? i'm trying to get my orion tv to go into aux mode without a remote. do you know how to do that?
1helpful
2answers
My orion tv
We had this same problem, and this is what resolved it. Unplug the tv from the wall, wait a minute, plug it back up, and turn it on again with the "power" button. This worked for us (without a remote).
Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
7helpful
3answers
TV stuck on AUX
unplug the tv then plug it back in the wall
1helpful
2answers
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
