Connecting a Bluetooth headset or car kit
You can listen to
music over a Bluetooth stereo headset, or have hands-free conversations
using a compatible Bluetooth headset or car kit.
It's the same procedure to set up stereo audio and hands-free.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices
section. When the Bluetooth headset or car kit is connected to your
phone, the Bluetooth connected icon is displayed in the status bar.
Depending on the type of headset or car
kit you have connected, you can then start using the headset or car kit
to listen to music and/or make and receive phone calls.
You need to turn on the Bluetooth of both the devices and search Bluetooth Speakers device from your phone and pair. After pairing you need to connect them. Next time you don't need to pair them, you can connect directly. I prefer to wear Bluetooth speaker to listen my favorite music, my Supertooth Freedom gives amazing sound quality also very stylish and comfortable.
get more details on supertooth.net/en/.
SOURCE: I have a H350 Blue tooth, I have a new phone, I forgot passkey.
Pin or pass code should be 0000.
SOURCE: Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
SOURCE: my plantronic 220 explorer blue tooth will not
Try to put it in pairing mode, prior to pairing it with your phone. To do it, begin with it turned off. Then, if it is the first time it is being paired, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the time required to turn it on (for some 8 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode.
By the way, if its user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
