First, the phone line to your fax machine should go through the filter.
Also, you haven't mentioned if you can just dial and call someone. Can you?
One way to test it is to dial manually as you would dial any telephone number.
Insert the document to be faxed, lift the receiver on the fax machine, listen for a clear dial tone, then dial the number.
If there is a fax machine at the other end you will hear the chirping sound after a few rings. Then press START and see what happens.
