Samsung DV218AEW Electric Dryer Logo
Posted on Jun 20, 2011
Is there a diagram of how to run the belt on the tensioner, have new belt around drum already. Don't know what it is suppose to look like. Thanks Dave Ball at ([email protected])
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 20, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
303
Points
Man Im not sure if this info will help you but. On my dryer which is pretty much the old style, standard type dryer and I had to replace the belt and had a little trouble putting it on the tensioner, finally figured it out.. If you take the belt and pinch it together and pull under the belt tensioner and then around the moter shaft that's what you do for the dryer style I have.. HOPE this may HELP!!
I have a 92 chevy geo prizm but i can't find a diagram to change the serpentine belt
If you've lost the sticker under the hood and there is no diagram in the owner's manual, you can find it in a Haynes or Chilton's manual for your vehicle. It may even be printed on the wrapper for your new belt. Most auto parts stores also have a copy of the diagram.
If you're stuck out in the boonies, the old belt is already off, and don't have any of this information, you'll have to work it out. Start by noting the grooved side of the belt is on the inside. The crankshaft pulley on the bottom is generally grooved. Look for the next pulley in line to the upper left from the crank pulley. It is probably smooth, so the belt goes around it counter-clockwise from right to left (smooth side). Next should be a grooved pulley, so the belt would wrap around the outside in the clockwise direction. Continue working your way around in this manner until you get back to the crankshaft pulley. The rule is "clockwise is groovy." Make sure you pick up all of the pulleys. As a check on your work, verify that the belt tensioner would pull the belt tighter when installed according to your diagram. You most likely have two or even three grooved pulleys in a row at or near the top - this will be a straight shot with no wrap around a smooth pulley.
The belt tensioner is generally a smooth pulley and is often the first one off the crankshaft pulley going clockwise. The A/C clutch, power steering and alternator are generally grooved. The water pump may be either one and is often the last one going back to the crankshaft pulley. It is rare to have two smooth pulleys in a row. The belt is never arranged so it contacts itself on a full wrap. If the belt is very loose when it's engaged on the tensioner, and the tensioner spring isn't broken, you'll have to rework your tentative diagram - the belt may go across the pulleys in a different order.
The most difficult part aside from working out the proper belt wrapping is loosening the belt tensioner so you can get the belt on. Some vehicles require a breaker bar and socket on the tensioner center bolt (there's no room for a ratchet). Others have a slot in the side of the tensioner where you can insert a large screwdriver to pull against the tensioner.
tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 • Dryers
tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
2helpful
2answers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
1helpful
2answers
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
tip
RCA Dryer Belt Diagrams and Replacement
All models use this diagram:
Installation Tips: Ribs against drum
1helpful
My dryer belt from my Whirlpool model number lgr7646dq1 snapped off and I need a diagram how the belt goes back on. I already purchased a replacment belt but do not know how it goes back on. Thanks Richard
the belt number 341241, that should be packaged with a diagram as how to wind it around the motor shaft , and the idler pulley.youll need to pull the front off the machine to gain acees to the drumm area, fom there you can drape the belt over the drum, "red side out"might be a difficult to try to hold up the drum and try to secure the belt without the use of another set of hands( the front panel that you removed holds the weight of the unit normally) afeter you get the draped belt around the ider pully "snaps into the lower cabinet so that you can pull hte tension to the right. after fully extending the pully to the right wrap the belt around motor pully and allow the idler to release and hold tension on the belt. it will only go on one way! only tricky the first time , youll get it!!!
2answers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
8helpful
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 • Dryers
Can't get drum belt on Kenmore dryer
Generally belt comes around drum then around pulley tensioner and then back to motor pulley in a zigzag fashion
May 06, 2017 • Dryers
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
