No, you do not. If you install IE8 over IE7 it automatically imports your bookmarks.
No you should not They should be transported over to IE8 when you install it.
It may ask you if you want to transport them over to IE8. If it asks choose to do so.
NO, they are automatically imported into IE8 as part of the upgrade process. To ensure you do not lose them you can make a backup of your favorites by following the directions below:
Backing Up Your Favorites
You can keep a backup of your Favorites in case you accidentally delete
any off your list. You can also use this backup to transfer your
Favorites list to a different PC or another browser program.
Click on the File menu (in Internet Explorer 7 click the Add To Favorites button) then click Import and Export. You should see a window welcoming you to the Import and Export Wizard. Click Next, then select Export Favorites. Leave the main folder selected on the Export Favorites Source Folder screen and click Next.
Make sure Export to a File or Address is selected, then Browse
to a location on your hard drive where you wish to store a copy of your
Favorites list. Type a name for your backup, for example MyFavorites and click Save. Click Next, then Finish and a window should tell you the export was successful.
The Favorites backup file is saved as a web page file and it can also be
opened in your browser like a normal web page by double-clicking it. It
will appear as a simple-looking web page containing your Favorites
links.
SOURCE: I downloaded ie8. ie7 is still on my computer and
Yes. In a nutshell yes. If Microsoft will let you that is.
If i were to give you my advice i would recommend opera. (http://opera.com)
It is generally better than most web browsers. But especially IE.
