My Sony Ericsson phone switched off and will not turn back on. I've tried countless times trying to turn it back on but apart from it vibrating a little and the Sony Ericsson sign coming up, it turns right back of. Please can you help me solve this problem. Thankyou
Have you switched off/on, and it's the same? I've got a Sony Ericsson phone and taking out the battery and putting it back in sometimes resolves freezing issues.
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Yep there's one solution. The problem what most of people do is they turn the device on while is still wet inside. When they do that (as you did), you will burn it as there will be short circuit. If you get your phone wet, NEVER switch it on until it's dry!!!!You should get 100% pure synthetic alcohol and (obviously without battery) put it in there so water will dilute with alcohol and it'll dry quicker without rusting any metal parts inside. You should leave your phone dry naturally up to 7 days on dry warm place(not hot). Phones usually switch off themselves when short circuit detected. So solution for you: put this one in the bin and get new one,you've burned your phone!!!
try taking out the battery & reinserting. i have had this problem 2x with a sony ericsson when my phone when so flat it turned itself off. last time i had to go to the shop where they plugged in their recharger then u cld turn it on.
the phone vibrates then turns off?
there is a battery issue causing the device to powercycle after starting up. the sony ericssons always vibrate when they are turned on.
long story short, replace the battery :(
you need to get the phones reflash with the original firmware.....you phone will be working fine after that....so take it to a repair center to get that done or go to topsony.com to do it yourself...but remember you have to pay for the firmware on that site.....but it works
