When the printer is connected to the network the first time, the router will assign an IP address to it. To get the IP address that the printer was assigned, print a configuration page from the printer. It will show you the IP address on that page somewhere.
Using an Internet browser, type the IP address of the printer into the address line of the browser and press enter. It should bring up a printer configuration window.
Now, since each printer is different, I can't give you the exact steps, HOWEVER, here's what you are looking for:
Find a Network - TCP/IP configuration menu. Somewhere in that menu, it will give you the choice of setting a manual or static IP address versus a DHCP (Dynamic Host Control Protocol) assigned address.
You want to manually set the IP address to the address given on the configuration page. This would normally be 192.168.1.10x where x is any number between 0 and 9. The subnet mask will normally be 255.255.255.0 and the gateway will normally be the IP of the router, usually 192.168.1.1
Once the IP address is assigned permanently to the printer as a static address, you are now ready to add the printer to each computer on your network.
Add the Printer to Your Networked Computers
In Windows XP, follow these steps to add the wireless printer to your computer:
