SOURCE: Screen stays black after laptop comes back up from hibernation
Its software,, format and reinstall windows
SOURCE: Acer laptop restarts repeatedly to acer erecovery management environment
did you reformat the hard drive first?if not then you needed to ensure that you selected 'repair' first.
SOURCE: restore factory settings to acer aspire laptop
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at http://www.vtechsquad.com/acer-support/
SOURCE: Windows failed to start, Status 0xc000000f acer aspire 4730z
aspire aspire d257 status 0xc000000f Info: the select entry could not be loaded because the application is missing or corrupt
