Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
Posted on Jun 20, 2011
I am at a romote camp...I have a 501htm3, I replaced the small drive motor and gear box that controls the drain v/v. The old part failed from water getting into the gear box and siezing the motor etc...the unit drains instead of keeping water in and running the washer itself...is there a way to set up the drive ie. do you align it clockwise or counter clock wise? and does the spring facilitate parking the drive in the open or closed position with regards to the valve it actuates...Doug
GPEC
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Oct 30, 2013
GPEC
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3062
Points
29
I would check the drain valve for fault.. Sounds like the drain valve is not closing this would cause the machine to drain whenever the motor is on.
1 Related Answer
Anonymous
  • 86 Answers
  • Posted on Jul 02, 2009
SOURCE: My 501HT has stopped draining.
Hello Dabean
Have you sort out your problem yet if not please email me your problems and I try to sort them out for you my email address [email protected] God Bless have a nice day Dickson
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Washer will not agitate or drain
No agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Timer was ruined from detergent dripping onto it. Replaced twice already. 1st would go thru cycle but not spin fast enough to dry clothes. 2nd would wash but not drain or spin.
those signs are not neccessarily ur timer, u may have replaced it for nothing. both spin and drain problems are likely located elsewhere?
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Washer drains but sometimes doesn't always spin. Seems to really hate heavy loads like towels. Sometimes a small amount of water is still in the bottom of the tub after the spin cycle has failed. I reset...
Depending what unit u have most don't have belts now days the have direct drive couplers or single unit motors which act as motor and transmission all in one but more to ur point sounds like ur motor is getting week and needs replaced
FEW 12 will wash and drain but wont spin
Hi
Thanks for using FixYa. Please check if some small clothes have been stuck in the water pump. If so, please take them out and clean it. The Water Pump is mounted directly to the motor. If still the issue persists, then it seems that the drive motor has gone bad if it fails to start after the water is filled up to the required level and if the motor is running but the agitator is not moving then it means that the drive motor belt is excessively worn. Please check and replace whichever is required. Also please check and reset the circuit breaker and check the fuse. Please remove the debris from the drain hoses and the drain. If it is clogged, clean it. Now close the door and press start/stop button and it will start to spin after the door is locked. Please revert back for further assistance.
Thanks
Rylee
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
How do you remove the agitator on a wash machine?
HELLO,
HERE ARE SOME SOLUTION BELOW
Machine Won't Agitate or Spin
  • Remove the pump and drive motor. You will find two plastic and one rubber motor couplings. One is located on the drive motor and the other is on the gear case with the rubber coupling between them.
  • 2 Pry or break the old couplings off with your screwdriver. Replace with new couplings. Simply push one onto the shaft of the gear case and press the second one onto the shaft of the drive motor.
  • 3 Line up the holes of the rubber isolation coupling with the studs in the coupling. Push the rubber isolation coupling in place.
  • 4 Push the isolation and coupling on the drive motor making sure that the holes line up with the studs on the other coupling on the gear case.
  • 5 Reinstall the drive motor and then snap the pump in place with the retainers to hold it in place. Reconnect the hoses with the clamps and snap the.Put the washer back on and screw the back in place. Position the washer where you had it before and plug the washer in
  • Washer Won't Drain If your Roper washing machine does not agitate, spin or drain, you have a problem that needs fixing. The average do-it-yourselfer can do this JOB without hiring the professional technician. Each problem indicates a separate repair, but while you have the washer apart, it never hurts to check things while the back is off and the parts are off the washer. EXERCISE caution and make sure that the washer is unplugged and the water is off before you begin.
  • Check the drain hose to see if anything is plugging it. Sometimes small pieces of material go out with the wash water and become lodged in the drain hose.
  • 2 Open the access panel in the back by removing the screws and taking off the back panel. Remove the drain hose. this is usually held on with a clamp, collar or clip.
  • 3 Use a pair of needle-nosed pliers to remove the obstruction. If the material is further into the hose, you can use a sturdy piece of wire with a small hook bent at the end. Stick this into the hose to try to pull the obstruction out. If you still can't reach the obstruction, disconnect the entire hose and force the obstruction out with a water hose using the jet spray.
  • Thanks.
    First the f4 light flashed and we turned it off and on again and put hot water down the pipe which seemed to clear it - then the water finally drained from the maching - then it kept repeating the last 15...
    Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
    Re select cycle and select HOLD to START.
    If the issue persists then the F11 error is a Serial Communication Error Between MCU and CCU - Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any wash cycle. Check MCU by looking for operation of the drive motor and check drive motor for powered rotations. Also check the motor and wire harness. Replace defective part as required.
    2answers
    Need oil change in water
    If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
    Frigidaire washer model FWX833AS1 top load
    Hello Lcl2610.
    welcome to Fixya,
    My name is Huuum,
    How old is your machine?
    I have found some reasons of what may be the matter!
    List of thinks to check
    1.Defective Lid Switch
    Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
    2.Faulty Direct Drive Coupling
    The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
    It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
    3. Faulty Water Level Switch
    If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
    4.Will not drain and displays F/02
    The error code F/02 will be displayed if the drain time exceeds 8 minutes. Press pause/cancel twice to remove display. Check the pump filter and wiring connections on the pump. If all looks good, replace the pump.
    You may want to use a pro, rather than attempt this project your self.
    Let me know how it goes!
    Thank you Huuum.
    Please remember to leave a rating
    Top Moyer Diebel Dishwashers Experts
    Mike Cairns
    Mike Cairns
    Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
