Washing Machines Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a bosch classic maxx washing machine WAE20260AU with probalm E2 what do i do now?
Anonymous
Level 2:
  • Expert 223 Answers
  • Posted on Jun 20, 2011
Anonymous
Expert
Level 2:
Answers
223
Questions
0
Helped
79747
Points
748
As you said in the question you are washing machine is showing the error code as E2 is nothing but Error signal due to long heating.If you want to get repair means you just need to contact you are nearest service center for service engineer.Thanks for your question.
1helpful
2answers
BOSCH MAXX CLASSIC E2 error reset, has water and drained, but the machine did not run/spin.
FROM FIXYA
Sanja Salatic NOV 29, 2009
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
To fix you must do a master reset of the washing machine.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
This worked for me
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
72helpful
What does error code E2 mean? I have a Bosch Maxx Classic.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
