Televison & Video Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when i put a dvd in, it just says root on the dvd player screen...really confused.
Steve Burt
Level 2:
Sergeant:
Champion:
  • Expert 245 Answers
  • Posted on Jun 20, 2011
Steve Burt
Expert
Level 2:
Sergeant:
Champion:
Answers
245
Questions
0
Helped
50094
Points
669
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Iview 2600 hd code for a RCA universal remote
There is no setup code to this device with Iview. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Iview 2600hd dvd player has error "this player is incompatible with the region marking of this disc"
DVDs are coded for different areas of the world. If you bought the DVD from an online source it may not play on your format of DVD player.
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
Trying to hook up Phillips DVD player and have 3 coaxial cables that need to be hooked into Sony TV and I have 14 holes for cables-help!
Don't use co-axial cables buy HQ SCART Gold Plated Ribbon cables with full 21pins then hook up the AV out of the DVD player into one of the AV in on the TV.
When you turn your player on it will autoselect the correct AV (audio visual) channel on the TV.
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
26helpful
4answers
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
