Here are the steps.Hope this helps.
Insert a putty knife between the top of the
kick plate and bottom of the front panel near
the center of the washer, if you have an older
model top load washer. Move the putty knife blade
in and out in that area until you feel an
obstruction. The obstruction is the kick plate
retaining clip
Press the putty knife blade over the spring clip
until you feel the clip disengage. Let go of the
putty knife and grab both ends of the kick plate
with your hands. Pull the kick plate away from
the washer
ift the front of the washer with help from a friend,
if you have a front load model Whirlpool. Slide a
block of wood under the front of each side and gently
lower the washer
Remove the three hex head screws on the bottom edge
of the washer kick plate with a Phillips-head
screwdriver or nut driver. Pull the kick plate
away from the washer.
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
