The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
SOURCE: problem with Nikon d90
unlock your card.
you'll get that message when the SD card is locked.
Lock the card only to prevent deleting photos from it.
good luck!
Alberto
SOURCE: nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
SOURCE: nikon d90 lcd screen
clearly not good! bring it to a repair shop is the only thing to do I guess.. good luck with it!
SOURCE: got my Nikon d90 for
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
