Question about Humminbird 997c Si Combo Color Fish Finder And Gps Chartplotter, Without Transducer
I have a humminbird 937c fish finder gps and chart plotter but i need a manual to tell me how to use it
  • Humminbird Master
  • 696 Answers
Hi!
No problem. Here's the link to your manual!
http://www.manualnguide.com/dl/15864/
Happy Boating!
Posted on Jun 20, 2011
  • Steve
    Steve Jun 20, 2011
    On second thought, stay clear of that link.
    THIS link is MUCH quicker. http://www.azmanual.com/download/15864/0...
    Hope this helps.
SOURCE:
My fish finder shutsdown or restarts when I start my main motor
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Apr 25, 2016 | Lowrance HDS 5 Fishfinder GPS Chart...
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
I get an error msg that the transducer is not connected. How can I check idf the transducer is faulty
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
Aug 28, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
Need to locate and print users manual for Humminbird Pironha Max 160 Fish finder
print users manual for Humminbird Pironha Max 160 Fish go to this link http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 13, 2011 | Humminbird GPS
Can i get a free manual for the matrix 97 combo fish finder / gps chartplotter.
Call our Customer Service Group at 800-633-1468 and they should be able to help you.
Joby
Humminbird
Feb 06, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
Our new 787C2 fish finder by Humminbird is not working correctly. It worked for our first view fishing trips, but now the display is not showing any color, structure or fish. It tells us the depth and...
This could be a lot of things. The unit employs multiple signals to gather data and it could be the transponder not getting the signal or it could be something simple like the sensitivity. Humminbird 757c Operation Manual Sensitivity
Feb 19, 2018 | Humminbird Fishing System, 787c2 Combo...
Owners Manual
I've heard that Humminbird will be happy to send you a manual, just fill out the contact form supplied here:
http://www.humminbird.com/support/faq.aspx?ask=yes
Apr 29, 2010 | Bottom Line Fishin' Buddy 1101 GPS...
Furuno 1850 has water in unit, only noticed
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 06, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Open Questions:
My Humminbird 997c SI is stuck in loading screen I had downloaded latest software updates for my Humminbird 997c SI and my 1197c SI.Then was attempting to update them one ata a time following typical software updates for these units like I had done in the past, resetting factory settings then running software update. My 1197c SI update perfectly with no problem, then moved up front to perform update on my 997C SI and went through same process as mentioned before. I turned around for less than a minute and turned back around to a black screen. When attempting to turn the power back on it started the loading screen and then stayed there for over an hour. I brought the unit inside and connected to the PC via USB cable and opened my HumminbirdPC. I made it to the Matrix Boot screen by holding the "View" button down and proceeded to toggle down to the #9 "Program" command and again pressed "View" to start to HumminbirdPC recognition sequence. My unit is not recognized by the software and the unit came back with a "Programming Failure" response. I have attempted this several times and even brought the 119c Si in to try,keep in mind the 1197C Si is up to date... However thinking that the 1197C SI would load and be rcognized, now both units have the "Pragramming Failure" response when trying to get Humminbird PC to recognize them!? I have my PC with Windows Vistaup to date as I just went through a 26 item update with windows, including service pack 2. I have all Drivers up to date, all Security updates and still no recognition. I thought maybe it was something with my PC... So I borrow my wife's work computer which is a Dell with Wi ndows XP and her company keeps it updated thoroughly. Same result... Then borrowed my Sons MAC that runs Parallels and has Windows 2000 on it. No Luck!! I have exhausted all ideas and could use some additional ideas if someone has any. Any input would be appreciated to get the 997C SI up to date. I have heard tha it is appx $200 to send it in to Humminbird and the new 998c is outrageuosly expensive. Thank you in advance for any HELP!?
May 29, 2012 | Humminbird 997c Si Combo Color Fish Finder...
Humminbird 997c Si Combo Color Fish Finder And Gps Chartplotter, Without Transducer Logo
228 people viewed this question
Top Humminbird Boating Experts
fordexpert
Bill Eager
Mike
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
