If some of the lists are missing press the STAT button then select SetUpEditor and ENTER to restore all of them (without data, of course.)
If the statistical plots are turned OFF you can turn one of them back ON again. Press SHIFT Y1= to access STAT PLOTS.
Press 4:Plots Off. A good habit to avoid problems. After you turn all plots OFF,
you must turn one of them ON if you intend to draw statistical graphs. You can for example Turn Plot1 ON.
- To do so Press SHIFT Y1=, select say 1:Plot 1 ENTER.
- Highlight ON and press ENTER.
- Press DownArrow to move to line TYPE
- Then you can set the plot type. You have 6 choices. Use the left/Right arrows to select one of the 6. The selected plot type icon will remain highlighted when cursor is moved.
- Use DownArrow to move to XLIST line and select the x-values LIST. etc.
- When finished Press 2nd QUIT to exit the stat plts configuration settings.
One statistical value that may be of interest to you is the R, R^2 coefficients. To have it displayed (if the regression model has it), you must set DiagnosticsON.
Press SHIFT 0 to enter catalog. Press x^-1 key to jump to the first command that starts with D.
Scroll down to reach DiagnosticsON, highlight it and press ENTER then ENTER.
