Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Plain and simple: most air conditioners (Haier) do not have drain plugs - if the A/C is spitting water, the back end is too high. Tilt the front (inside) higher than the back (outside) and this should alleviate the problem.
SOURCE: Dehum
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
SOURCE: Haier Model# HWF05XCK-L 5000 BTU window air
The problem you're experiencing is generally caused by the rear of the unit not being tilted down enough. 1/4" to 1/2" is the general rule. This allows collected water in the drip pan, to run to the rear of the unit, where the drain hole is located. It would also be prudent, to check the drain hole under the drip pan, to see if it's clogged. It can be cleared with a pipe cleaner.
Hope this helps you and thanks for choosing FixYa.
