Haier 45-Pint Dehumidifier Logo
Posted on Jun 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for temperature sensor control for Haier Model DE45-RBG Numbers on part HSU-07 88A MC3A 94V-0
Kelly
Level 3:
  • Haier Master 3,740 Answers
  • Posted on Jun 19, 2011
Kelly
Haier Master
Level 3:
Answers
3740
Questions
Helped
2163085
Points
12091
Here is the data sheet for the HSU-07.
http://www.maocc.com/pdf/hdk/e1321aa.pdf
There appears to be 5 different versions of the HSU-07 Let me know which one matches yours and I will try and find a source.
HSU stands for humidity sensing unit.
Keep me posted... on the actual part match per the pdf file.
Kelly
1helpful
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
The humidiy control is not working. the only time it will run and when I lower the humidity control to on
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Your Manually Controlled unit
should be turned to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humid-i-stat sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
1helpful
Unir ran good for 8 months then cut off with current humidity reading LO. Humidity is not LO. Have to set below 40% then runs all the time. The AUTO humidistat sensor must be broke. 1 year...
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Our Haier runs but does not remove any water from the air
Paula, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I have a Haier DE65EA Model and I turn it on, but then it shuts off after about 30 seconds. The bucket is not full. I have lost the owners manual for it.
level
problem.
Your particular model has been retired. However, the Owner's Manual for the replacement (much like yours) is available at the following link. http://www.haieramerica.com/en/asset/product/31b6415af4
You can download & print it for future reference.
I hope this helped you to troubleshoot & solve the problem.
Can't get our dehumidifer to run. It show all the numbers but doesn't want to run to plull humidity out of the air.Can't find my manual book so we know what to have numbers at. Can you send me...
Bonnie, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helped you tho troubleshoot and solve the problem. Please let me know. Thanks.
2helpful
I have a 45 pint haier dehumidifier that is plugged in, everything lights up, but doesn't run. What's the deal?
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
problem.
Hope this helps to troubleshoot & solve the problem. Please let e know.
1helpful
Unit fan running but does not take any moisture out of the air....bucket has not even a drop in it for three days.....moisture on floor even in basement area
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1, 2 & 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manually
controlled unit, set the knob on Maximum.
(Unless, you have a Low Temp model). This applies mainly to
in basement applications level. Raising the unit up off the floor,
problem.
Hope this helps you troubleshoot & solve the problem
Hi I have a Haier Energy Star Dehumiderfier. The plastic water container that holds the water was washed yesterday to remove dirt,etc The plastic piec on it loosed and now the unit won't turn...
Yes, that part (Bucket Activation Switch) can be purchased directly form Haier.
For Repairs & Parts in USA & Canada, call 1-877-337-3639 OR click on the following link.
http://www.partlinx.com/haier.asp
Hope this helped you. Please let me know. Thanks.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
