You got the wrong keypad for your opener. Be careful who you buy from.
Are you sure that I bought the wrong keypad ? It did work when I programmed it but then the remotes no longer worked, so I had to switch it back so that the remotes worked. I bought the Chamberlain universal remote which is supposed to work with Sears Craftsman. Do you happen to know the correct keypad that I should get instead ? Thanks for your response.
Ok so I am in Canada and I bought this used Craftsman remote keypad that you install on the side of your garage door on the outside of your house. I assumed that as long as the keypad brand was Craftsman, Liftmaster, Chamberlain or Wayne dalton, that any keypad of these brands would work with any of these brands of garage door openers. WRONG!! I spent $40.00 for a used keypad only to find out that it is not compatible. So to avoid you all from making the same mistake...here is what I learned or know now. First off it is very important to try to find out what colour the square plastic learn button on the actual garage door motor was that the remote keypad you are looking to buy , was used with. It is also a good idea to find out what the FCC ID # is on the back of the remote keypad you are looking to buy.Once you have the FCC ID# for example mine was FCC ID# HBW1631. You can type into Google searchbox "FCC ID# Lookup" and that will take you to the FCC's website. If a search box does not automatically pop up, you scroll on the left side of the page and look for "FCC ID Search". A box pops up. The first box is called "Grantee Code (first 3 to 5 characters)...mine was HBW. The second box underneath is called "Product Code (remaining characters of the FCC ID#).......mine was 1631. Hit search and a result should pop up, In that result you see a lot of info but at the far right you will see the lower and upper frequency range of your remote keypad you are either selling or planning to buy. Mine was 315MHz upper and lower range. So that means that my remote keypad will only work with garage door motors that operate on or between a lower and upper range of frequencies that include 315MHz. Now we have to find out what frequency the garage door motor is. If you are buying the remote keypad....as the seller what colour the Learn Button is on the garage door motor. For my remote keypad I bought, it worked with a Green or Purple Learn Button on the motor. So the keypad I bought would not work with my motor with a red learn button. To find out what frequency your garage door motor operates at, you can either call customer service for the brand you own and give them the model number.Or Google the model number to search what frequency the motor operates at. I had a hard time googling it so I just called Chamberlain customer service and they told me my motor is 390MHz. So now I know the frequency range my garage door motor operates within, I can look for used remote keypads, ask the seller what the FCC ID# is, then type it into the FCC ID Search Lookup website to see if the remote keypad frequency falls within the operating frequency range of the garage Door Motor. Hope that helps a bit guys and gals. Kev
