Error code sc 101.... sc 350
What is the meaning of sc 101 and sc 350 .....how can i fix it.....
  • 5 more comments
  • thraser
    thraser Aug 21, 2008
    tenkz... wer can i download the sc code meaning so dat everytime i encountered service code i can easily detect and repair the problem....if i can.... tenk a lot
  • thraser
    tenk but i cant find it in copytechnet ....
  • thraser
    thraser Aug 22, 2008
    tenkz a lot bubbabear ...it will help me a lot in my machine trouble.....how about the procedure hw to repair afficio 450 is der any link about it.... plz..... cuz i want to learn how to fix my own copier...
  • thraser
    thraser Aug 26, 2008
    bubbabear if il format the hard disk of my afficio 450 wat will hapen... i want to format it so dat i will have a new fresh program.... hw wil i do it...??? can u help... tenkz
  • thraser
    wat will be da best setting .... to avoid overtone in my afficio 450 i change the toner supply rate 20 and toner suppl correct. 2.0...TD sensor manual set Vts 4.37
  • thraser
    thraser Aug 27, 2008
    oki....tenkz a lot ...tenkz in advance....
  • thraser
    New Friend:
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Posted on Sep 05, 2015
    New Friend:
  • 3 Answers
Error code SC-101 for Ricoh Aficio 350
- exposure lamp defective
- camera
- scanner board
Error code SC-350_01 for Ricoh Aficio 350
- clean the sensor above the drum unit
- clean the drum unit
Posted on Mar 06, 2013
  • 2,794 Answers
SC101 Scan Lamp Error
Posted on Aug 21, 2008
  • 3 more comments
  • Tim Babcock
    Tim Babcock Aug 21, 2008
    Check on copytechnet.com. They should have a link for Ricoh error codes...
  • Tim Babcock
  • Tim Babcock
    Tim Babcock Aug 22, 2008
    There is a link on there for that as well.
  • Tim Babcock
    Tim Babcock Aug 26, 2008
    I asked that a few times and you need to have the firmware on pcmcia cards to do it.
    It's not going to help with the performance of the copier by doing it. It isn't recommended by Ricoh.
  • Tim Babcock
    I'll have to check that one out.
SOURCE:
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
Error code sc 23-04
What model is this machine?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 26, 2014 | Konica Minolta Office Equipment & Supplies
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
What does error code E05-73 on my Panasonic DP-C263 mean and how can I fix it?
E5-73 is a HDD Abnormal Operation. First try turning the system off, counting to 30 and turning it back on. If it persists you want to check the HDD connections. May be a failed HDD. Panasonics exact answer is:
1. HDD connector is disconnected.
2. SC connector is disconnected.
3. HDD is defective.
4. SC PCB is defective.
Apr 10, 2012 | Office Equipment & Supplies
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Ricoh Aficio 1515mf SC 121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Apr 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
2,674 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
