Lenovo 3000 J Series 1.80G VBE PC Desktop Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Lenovo 3000J desktop has continuous beeping sounds when I turn the computer on and does not load the operating system. What can I do?
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Jun 18, 2011
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528612
Points
5915
This beep is possibly telling you your hard drive is having an issue.
the boot sector is probably gone and you will need to format the drive, or buy a new one and install it.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Bois on d h215
Are you trying to enter (get into) BIOS?
This is for another model of Lenovo on the Lenovo.com website, but it will likely still work:
How to enter IdeaCentre Q700 BIOS setting screen
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut
down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear
multiple beeps, release the F1 key.
To start the Setup Utility program, do the following:1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Lenovo 3000 j series was working fine then looked at screen and it was all squiggle lines and computer seemed froze. i manually turned it off and waited. i then turned it back on and there is no video
First, is the computer coming on, do you hear the boot up beeps and sounds. if that is happening, try another monitor, if that works, buy a new one, if that does not work, repalce the video card. if none of that works, take the machine to a local shop for analisis. This might remotely be caused by a virus, but if you are using a good virus protection, it should have caught it.
Three short beeps one short beep
Did you add a card in the computer recently ?
check the manual here page 30 for the list of beeps
http://download.lenovo.com/consumer/desktop_pub/lenovo_h4_hmm.pdf
it mentions :
"4 beeps : Motherboard timer not operational" (whatever that means, it sounds like something prevents the motherboard to work correctly), and recommends to remove any card added in the computer one at a time to identify the culprit.
10helpful
2answers
How do i reset my lenovo desktop to factory setting
If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open.
Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK.
Related topic:
How to Factory Reset Samsung laptop?
2answers
Steady continuous beeps & computer doesnt boot..?
Its mostly an RAM problem, you need to check you PC RAM. Also use a sytem utility software RegInOut to optimize your PC. RegInOut is a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of Internet Optimizer enhance users web browsing experience.
My system is HP G60 with window 7, making this continuous beeping sound on starting window, does give sound from hibernation. Sounds up to 2-3 minutes before the start up can continue.
Beep codes are codes used for troubleshooting hardware issues. Kindly read my Tips and Tricks to give you a better idea. click here
Here's a link to guide specifically for HP and Compaq computers. click here
Hope this helps.
1helpful
Lenovo 3000 K100 Beeping
There are two types of beep, the continuous one with the same interval ,it indicates memory problem, but if the beep with two short beep the graphics card has a problem.That works?
Estoy buscando los driver de video compatible vga de una lenovo 3000j
WINDOWS DRIVERS
WWW.WINDRIVERS.COM
WWW.DRIVERSHQ.COM
GO ONLINE AND TYPE THE FOLLOWING INFORMATION AND THAN ENTER KEY
MANUFACTURES NAME, MAKE, MODEL.COM/VGADRIVERS
2answers
Beeping sound
take out the RAM then put it again, then check
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
