It is usually calcium-carbonate and lime.
Once the stuff gets into water lines, it can clog elbows and pipes and cause low water pressure.
If pressure is good, then clean out faucet aerators, and install water softener/filter
Generally a water-softener and filter can solve future problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
If you have tankless water heater, then delime the unit:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
If you have tank-type water heater, then clean out the unit
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
