Question about Homelite Mighty Lite Lawn Trimmer
Need to know the gas ratio to use in a homelite(trimlitr) weed eater.
  • 407 Answers
50:1 if that is too rich the weed eater will give off white smoke then use 30:1
Posted on Jun 18, 2011
SOURCE:
Toro manual weed eater model 51974
Jul 10, 2008 ... All Weed Eater brand gas trimmers require that oil be added to the gas in a ratio of 40:1,
You can Google these questions
Jul 06, 2018 | Toro Garden
Lost manual does this weed eater take regular gas or is it a mix
Want to give us a hint as to what kind of weed Eater this is? Most gas models use a mixture but the ratio can vary between manufacturers.
Jan 08, 2015 | Homelite Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas to oil ratio for weed eaters?
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
I hope this helps.
Jul 16, 2011 | Homelite Garden
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Apr 24, 2011 | Homelite Mighty Lite Lawn Trimmer
What's the gas ratio homelite Z825Sd weed eater? Is it 20 to1, or 40 to 1, or 50 to 1?
Older two-strokes were at 20:1 in the days before EPA mandated exhaust emission restrictions and controls. Some of the new equipment lists at 50:1...but I would go with the 40:1 to be sure....and use synthetic oil for best results.
Sep 04, 2010 | Homelite Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Weed eater wont start,put straight gas in it.
if you didn't mix any oil with the fuel,you probally burnt the piston and cylinder up.the only to find out if you did is to pull the muffler off and look inside the cylinder and see if there are any scoring on the piston.if there is you need to replace the piston and cylinder assembly.most cost $100.00 or more.usually they are not worth repairing.i know this is not good news but i hope this helped,let me know.................
Jun 02, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite Mighty Lite Lawn Trimmer  Logo
198 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
