Dehumidifiers Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jun 18, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103443
Points
14643
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
1helpful
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
1helpful
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
We have a model AD-40A dehumidifer that I believe is approx 3 years old. When the unit is plugged in, nothing happens. Although it appears to be getting power (when you pull out the water tank, the...
You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
I have a Silhouette dehumidifier model # DDR583R which is about 2-3 yr old. The red light indicating a full tank is on and no water is collected. When I checked the sensor & manually pushed it the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
1helpful
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
2answers
Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Won't Power On
This reply does not solve the problem, however my MAYTAG M7DH
45B2A DEHUMIDIFIER had the same problem.
Circuit Board COR 268BV1.O had circuits burned (on lower side of
board). The circuits that showed signs of arching were the right end
of D1, D 2, D3, D4, and at C2, C3, C4, C5, J1, O1,.
Apparently water must have entered the area and shorted these circuits. But I do not know. The only alternative is to replace circuit
board or junk it
MY LAB
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
