Sadly you are wasting your time as even if you can repair the lens element you lack the lens collimation equipment needed to set it up correctly.
By far the easiest, quickest and cheapest option is to sell your camera as a "spare or repairs" example and to use the funds towards another used example in good working order.
You have the added problem that when the lens did get stuck and you forced it free, you may have broken other internal lens parts. Even a professional repairer would not try to fix the lens assembly, they'd just order in a complete new lens assembly and fit that instead. The cost of the part alone, even without labour charges, will exceed the cost of buying another fully functional G5 privately.
Hi
Thanks for using FixYa. To start with try to blow
compressed air around the lens cover so that if there is any dirt it cleans if
off. You can also stick a thin strip of paper between the lens shutter and the
outer support ring & move it in a way that it clears the debris that's
stuck in there. If still the issue is not resolved then you'll have to replace
the lens assembly & lens mechanism to fix this issue. It is recommended to
be done by a professional. Please do rate the solution if the issue is resolved
or post a comment for further assistance.
Thanks
Rylee
