1996 Jeep Grand Cherokee Logo
Anonymous Posted on Aug 21, 2008
96 jeep grand cherokee wont start
Motor turns over good, battery good, fuses and breakers good.
I have no fuel pressure and no spark. No volt gauge and no gas gauge. I have swapped the pcm to my 97 grand cherokee and the pcm started my 97 just fine. swapped out ignition switch and that didnt work.
NO spark
No fuel
No volt gauge
No fuel gauge
scanner will not connect to obd hookup, says no communication.
PLEASE PLEASE HELP
  • 9 more comments
  • Anonymous Aug 21, 2008
    sure thing, you can call me at 330-507-4737, i have checked all fuses though
  • jhill35602 Aug 21, 2008
    EXACT SAME PROBLEM, ACTS LIKE A SHORTED CRANK SENSOR -BUT CRANK SENSOR IS FINE
  • Anonymous Aug 22, 2008
    cant be a crank sensor, because on the 96 the crank sensor does not control fuel. this jeep wont even attempt to fire up, turns over perfect, but no spark and no fuel pressure
  • Anonymous Aug 25, 2008
    Hi. I have the same problem vith my 96 jeep, 4.0l. No spark , no fuel presure and no riding on same of the gages.
  • Anonymous Sep 05, 2008
    motor turns over good, battery good, fuses and breakers good.
    I have no fuel pressure and no spark. No volt gauge and no gas gauge. I have swapped the pcm to my 97 grand cherokee and the pcm started my 96 just fine. swapped out ignition switch and that didnt work.
    NO spark
    No fuel
    No volt gauge
    No fuel gauge
  • Anonymous Sep 09, 2008
    I have the same exact problem- no fuel pump activity, no spark, no fuel guage activity and no volt guage activity- engine cranks strong, 3/4 tank of fuel- did notice the power lead for the fuel guage and the ground wire for the fuel pump by hte tank were bare and possibly touched- could have shorted the PCM?
  • Anonymous Mar 14, 2014
    i took gauges out of 96 jeep grand cherokee and now alarm wont shut off
  • Anonymous Mar 18, 2014
    Fuel pump is loosing pressure after it sets for a while
  • Anonymous Mar 19, 2014
    driving ran good quit running wont start gets spark and gas
    4.7 quit running gets spark and gas
  • Anonymous Mar 21, 2014
    also have spark and fuel made sure cylinder1 was up
  • Anonymous Mar 26, 2014
    fuse for fuel gauge on dash board
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2662
Points
12
My 1996 jeep is doing the same thing.the fuse I have been changing is under hood in fuse panel on left 20 amp sm. in center of fuse panel closest to bat.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3393
Points
6
Ok, I had a very similar trouble. It cost me a lot in diagnostic time, but here's what my mech. found.
Symptom, no fuel flow. I don't remember the guages status. Fuses and relays were good. but had blown fuel pump fuse in the past.
Found: Hose connector (A.C.) in vicinity of the fuse box under the hood. (underneath) was chafing the harness from the fuse block to fuel pump, guages, etc. wiggle adjustment temp fixed. Mech found short/ground/ exposed copper wire and repaired the connections. also, protected wire from future damage.
A poorly place connector / harness and vibration were the contributors to the incident. Fix was good and so far permanent.
Anonymous
Level 1:
  • Posted on Oct 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2662
Points
Let me guess- your check engine light doesn't light either, does it? Unplug the crank sensor and turn the key on. If the check engine light comes on, replace the crank sensor and drive away happy. That's what I did. You can also verify the crank sensor by using an ohm meter- if you get a resistance reading, the crank sensor is bad. Good luck. I believe it's the black and red wire you need to pull the reading from- but honestly not positive.
Anonymous
Level 3:
  • Master 335 Answers
  • Posted on Aug 21, 2008
Anonymous
Master
Level 3:
Answers
335
Questions
Helped
158856
Points
1013
You have a blown fuse in the POWER DISTRIBUTION CENTER I cannot find it in my database it will be a big maxi fuse that feeds all the sircuite you mentioned. call me at 253-235-0057
and I will try to talk you through it.or give me your # and I will call you I would like to help you
  • Anonymous Jan 26, 2013
    RANDY i have replaced every fuse and relay to no avail still have the same issue as before . new ecm new ignition coil plugs wires cap rotor dist pick up assy fuel pump module fil new crank sensor also new alternator new battery cables and battery all done in the last 7 days. any light you can shed on this for me is deeply hello randy thx for info but have all new fuses and relays in PDB spent over 1.000 dollars in last seven days. no fix yet please help if you can ready to junk this thing live in ohio 45356
96 jeep grand Cherokee has no power to fuel pump or ignition
define power.
1: can't hear buzz?
2: fuel pressure at the fuel rail is zero PSI cranked.
3: my volt meter tells me the pump has 0vdc across the pump pins cranked?
I cant guess any of this and is 100 %^ Germain.
4answers
Ive got fuel at the injector rod on my 1994 v8 jeep grand cherokee larado but the car wont start .. this all comes after runnin out of gas. its almost wasnts to but doesnt stay on at times and now won
If you ran out of gas there is a very good chance that the fuel pump relay has blown a fuse or requires a reset. Fuses and relays are in the main fuse box behind battery. When you turn your ignition on to the one setting before the starter engages you should be able to hear the fuel pump running. If it does not then check those fuses. If it does run then there is a good chance that the crank shaft positioning sensor needs replacement.
3helpful
2answers
When i start the engine on my 04 jeep 4.7 liter engine it sputters but clears up and idles good and it runs good no loss of power and no check engine light. it happens when it sits for a priod of time i...
The first thing i would check is the fuel system hook a fuel pressure gauge up to the fuel rail and check the fuel pressure, after you have verified the fuel pressure is good let the gauge sit and monitor how much "bleed down" occurs if the bleed down is out of spec i would bet the fuel pressure regulator is bad or theres a leaking fuel injector causing fuel to drip into 1 or more of the cylinders causing a rich condition at startup.
2answers
96 jeep grand cherokee no start. Has no spark, replaced coil, still has no spark. fuses and relays in power distribution all good, also fuses in cab all good. no codes in ecm. plug at coil has...
the crankshaft position sensor located between flywheel and trans is where the power source for the coil comes from. I suggest you need change that
1helpful
3answers
I have a Jeep grand cherokee laredo and i have installed a new fuel pump and fuel filter but it will not start i have checked all fuses and relays please help.
Having same issue with my 2000 grand cherokee. sometimes fuel pump will prime and car starts the other 50% of time no fuel pump noise only smaller radiator fan will come on and make vibrating whining noise. I have changed out fuel pump and filter as well as checked and ruled out all fuses/relays involved. Need help too
2answers
Grand cherokee 2000 starting probs
you need to see if you have spark and check all fuses and see if you have fuel pressure and injector pulse if no spark and no injector pulse suspect crank sensor or ignition control module if no fuel pressure check fuses then relays and then suspect pump
Engine will not start
check all grounds first then start tracing looking for burned wires
Power everywhere but the gauges and now won't start.was running put in reverse and it died ?checked the fuses and now lost help
What have you done so far. Need to see if the vehicle has both fuel and spark. Check the battery cables and inline fuses. Is it a crank/no start or no crank. A cold battery should be at 12.6 volts, should charge @ around 14volts., If you have spark @ all 6 plugs then see what your fuel pressure is. then go from there. let me know how it is going.
9helpful
2answers
96 grand cherokee crank no start, no spark from
have the crank sensor replaced this controls the spark and injector pulse it is located on the drivers back side of the engine above the transmission housing!
4helpful
4answers
1996 Jeep Grand Cherokee no start
I just fixed the problem with the 96.
Crank no start
No fuel pressure
No spark
No volt gauge and no fuel gauge
No scanner obd working when hooked up says error no communication. With the help of this awesome guy randy from washington, i did some relay jumping, more wire tracing and found it was the crank sensor was shorting out with just the key on. with key on, locate the crank sensor behind the valve cover, unplug it and see if everything comes back on, this is what it did for me. Thanks again randy for the help and this gentleman can be reached @ http://www.aceautomotive1.com.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
