Disable the adapter in the change adapter settings page. Then re enable it and try it. You can also remove the driver from device manager and reboot, windows will automatically reinstall the drive and it may work. USe the troubleshooting app to fix or detect the issue. If the connection show it has internet but you can't reach a page, try another browser.
SOURCE: Failure to install D-link Air DWL-122 on Windows XP
I think the D-Link Adapter is a piece of ****. I have tried 3com and netgear and they all work well. Try setting Static Address instead of dynamic. Saying that - I didn't power down either as the instruction manual is totally useless.
SOURCE: D-link WDA-2320 wireless adapter keeps dropping signal
are you using XP if so you can restore your computer back to a date when it was working or you can try this
Use the Windows XP SFC command to have windows scan and repair
files; to run this command, follow the below steps. Additional
information about the SFC command can be found SFC
command page.
Once the above steps have been completed, Windows will verify
that all protected windows files are intact.
SOURCE: Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
SOURCE: I have D-Link AirPlus DWL-G630 Wireless Adapter, I
go to this link thanks please rate the answer
Here is the link
SOURCE: the d-link adapter keeps going on then off every
Try another USB port if it's the power. If the same occurs, then try a powered USB hub which are relatibely inexpensive. If it's the signal that keeps dropping then you may need a higher powered router/apapter. I find PCMCIA and internal ones more reliable.
Please rate me if this helped J
