1997 Oldsmobile Aurora Logo
Posted on Dec 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'97 Olds Aurora - AC stopped and check charging system light came on - next day car would not start or take a jump. replaced battery (was at 9.3 volts), car starts but still says check charging system. Where should I start so I don't go down the path of changing and spending money on wrong solves? thnx bg
Jerry Lantz
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 65 Answers
  • Posted on Dec 16, 2017
Jerry Lantz
Expert
Level 2:
New Friend:
Night Owl:
Answers
65
Questions
Helped
16641
Points
196
Well do check the output of your alternator... if equipped with extrior voltage regulator , if the alternator output is 14 V
then replace the regulator...
Bill Boyd
Level 3:
Top Expert:
  • Oldsmobile Master 53,816 Answers
Bill Boyd
Oldsmobile Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11926260
Points
172802
Have a battery load tested
battery should be 12.5-13.5 volts at rest and no lower than 11 volts while cranking
next have an auto electrician to a charging system check
check that the drive belt is in good condition and tensioned properly
5 Related Answers
Scorpedo
Jamie Heppner
  • 111 Answers
  • Posted on Jan 07, 2009
SOURCE: check charging system light on 1995 olds aurora
Usually its your alternator, the light comes on when your charge voltages drops below a certain level.
Anonymous
  • Posted on Jan 26, 2009
SOURCE: car wouldn't start battery good lights work had starter replaced
you should check if the Fuel is flowing properly
Anonymous
  • 40 Answers
  • Posted on Mar 05, 2009
SOURCE: 97 olds aurora wont start
did you get the tumbler from the dealer because some have coded keys
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Jul 18, 2009
SOURCE: 97 Olds Aurora, headlights go on, tail and dash goes off
You have a bad ground. The frame of your Jeep, (As in most vehicles), is the main ground source.
All ground connections go to it, via some sheet metal, or directly. The ground wire from your battery will be connected to your frame.
Your headlights will pull at least 30 Amps. So will your taillights when the brake, and main lights are on.
Since you have a bad ground, (Or Grounds), your ground source cannot support both headlights, and taillights. Your dash lights? They should be on the same circuit as your taillights.
How to solve this problem?
1.Start with the the two ground straps, that are supposed to be connected somewhere on the back of your engine, and lead up to the firewall. If you have had any mechanical repair, and it involved removing the engine, or a cylinder head, (Or two if you have a V6), the mechanic may have failed to connect Both flat ground straps back up. Or one, or more, of the ground straps are loose, and/or corroded at the connection to firewall/engine.
2.Checked okay? Go to the front wiring harness. Out of this harness will be wires going to the headlamps, and turn signals. There will also be one, or two wires that are a ground. They should have a round metal terminal end on them. They will connect to the front sheet metal somewhere.
They may be loose, and/or, have corrosion under the metal terminal to the sheet metal connection.
Remove the terminal end, and check for corrosion. Use sandpaper, or steel wool to clean the contact surface of the sheet metal, and the terminal end. Lightly coat the terminal end with a corrosion inhibitor you can buy from your local auto parts store. It's in a spray can.
No problem so far?
Check each headlamp socket for corrosion. Means removing the headlamps. (Yes I know. Pain!)
If your Jeep uses Krypton bulbs, don't touch the bulb with your fingers. Use rubber gloves, or a Very clean rag. The oil off of your fingers will greatly diminish the life of the bulb!
Okay so far?
Go to the rear of the vehicle. Check the rear lighting harness, and it's ground connections. Check the lamp sockets.
Jerry Parmanand
  • 449 Answers
  • Posted on Oct 19, 2009
SOURCE: Would you replace a 3.5L engine in an Olds 2001
Buy something else.
Olds aurora 4.0 cuts out at stop lights but starts back up.
Dirty throttle body, restricted injectors, bad engine coolant temperature sensor, weak ignition coil or coils .
I have my old mobile aurora 2001 when try to start my relay is click but when start to direct to starter is crank for few secons and going off I have good battery
1) Could be the charging system (alternator). Get the car running, jump or charge the battery. Next, measure the voltage at the battery. With the car running, this should be 13.7 to 15.1 volts. If it's less or more, then you will need to replace the alternator/regulator - one unit.
2) Could just be a poor cable connection. Remove and clean the battery connections - large cables. Make sure they are properly attached, then try starting again.
ELECTRICAL ISSUE IN SUBURBAN
if the bridge (three diode that turn AC current to DC in alternator) is bad it causes internal draw
Hi my car wont start,after i get a jump it will run that hold day then the next morning nothing will come on no lights anything
your charging system is working okay or you would have to have it jumped more than once a day.you have a bad battery that needs replacing as running it during the day the charging system keeps the battery charged up enough to work.you could have a drain on the battery from something in the car that is not shutting down that you will have to have checked out.or sitting over night the battery runs down to the point that it needs to be jumped started if its an old battery(over5-6years).
1helpful
2answers
I have a 2001 olds aurora, wont start. Doesnt click or nothing, tried jump starting it dont do nothing. Battery is only 2 years old.
when you turn key on is there power to lights radio dash ? if yes check the starter relay and solenoid you can check easily using a test light find a good ground and a test light that works test light on battery first at the starter there will two wires one thick and will lead to battery the other wire is thin this is the wire you want to test have someone turn key to start while you test for power at wire if there is power at the wire replace starter the solenoid is deffective if there is no power at the starter sol wire then check starter relay
hope this helps leave me a comment and vote this was helpful any more questions reply
2003 olds aurora charging system low volts
The alternator is most likely the problem, it isn't putting out enough of amps to charge the battery, but enough to keep it going which won't last long. Before assuming the battery or alternator, try your battery connections for corrosion or tightness. If you live close to an auto parts store they can check the battery and alternator to see which is the problem. The battery will not hold up long if running lights at night or other power consuming things.
4helpful
1helpful
Check charging system light on 1995 olds aurora
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
