Typically the ones marked "input".
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
SOURCE: Installation
take two out puts from your cd player and run them in the inputs of the equalizer and believe me they are going to work.Remember if the outputs from your CD player are of high note (out put)the volume should be kept at minimal to avoid the rumble.
SOURCE: help
red -power
black/casing - negative(ground)
orange-is memory/ignition on
the rest are right'left outputs
SOURCE: how do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
SOURCE: I have an Alpine 3311 Eq, a 3512 amp and a 3518
I have the 3311 manual. Do you still need it?
SOURCE: dose the pyramid 801 EQ
The answer above is correct, but additionaly, it ONLY has speaker lever INPUTS as well,
