Mcdevito75 here, Hello Daniel, there are several ways to open a watch depending on the kind and make of watch you have. If you can, send a photo of the back of your watch to me at my email, [email protected]
? 7:52
https://www.youtube.com/watch?v=Y37okQAN7uA
Jun 16, 2010 - Uploaded by WatchDudeMark
In this video I will show u how to size your watch band with around the ... didn't need to watch it as you're obviously too fxcking useless to do ...
33 mins ago - Generic Ladies TFX Stainless Steel Watch W/ Rectangle Face ...watch? The clasp won't open and I didn't want to pay $65 just for a new clasp.
at the back of the watch, look at the upper side of the watch there is a small opening that means that is the side where you can open it. just use a knife opener or a small flat tools to open it. i hope this helps you a lot.
most of this kind of watch can be open by a skilled repair man using a knife, you can try it. but the hard part is not opening it but closing in the cover. it is close by pressing in at the sides of the watch. Better to see a repair man for this.
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch. 2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open. 3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it. 4)Pull the crown straight out. The crown and stem should come out easily. To open the back of the watch 1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case. 2)Match the size of your Rolex case with the same size of grooved metal die from the tool set. 3)Put the metal die on the grooves on the back of the watch case. 4)Turn the die to remove the case. 5)Remove the rubber gasket. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
To open the front, try a toothpick in the hole. You will need to get the stem replaced.
To open the back:
Flip the watch over and look around the edge. There will be small slots. A thin blade like a pocket knife will open the back cover. Carefully, put the knife blade into the slot and twist it open. There isn't much user serviceable stuff inside.
There is different proccedure for different watch to take out the back. Following are some of the proccedure to open the backcover of the watches:-
1. Some plastic watch have four screw in the back, you just have to unscrew the screws and take out the back.
2. Some of the watch have press back technology, which enables the watch to be water resistant and thus, the backcover of these watches are pressed very tight. You just need a back opener, and at the back if this back opener has to placed between the case and backcover and has to be tilted and backcover can be opened.
(Backopener is a tool which is like thick & hard blade with sharp edges like knife but not very sharp; these edges can get easily between the gap of backcover and case. - this tool can be obtained from any watch tools store easily)
