Employee's mailbox locked and No one knows Admin password
Our admin password was apparently changed from the default (I think the default is supposed to be 1020000? We've tried several, including 23646, to no avail...), but no one knows what it is. Now someone's mailbox is locked because they couldn't remember their password, but we don't even know how to log in as the admin in order to reset the password. Any help??
I solved it. I reset the administrator password back to default by using Feature 985, 9 -- 73738767793. That set the admin passcode back to 1020000. Then I was able to reset the mailbox passcode by using Feature 983> Log: 1020000> Mbox>Change>(extension)>reset.
Need to change voicemail. First need to reset the passcode since I do not know the passcode to this phone. I use the steps to reset the passcode under admin, however I get mbox locked prompt. How can I reset the passcode back to admin 1020000?Need to change voicemail. First need to reset the passcode since I do not know the passcode to this phone. I use the steps to reset the passcode under admin, however I get mbox locked prompt. How can I reset the passcode back to admin 1020000?
I have the same problem. not even the phone tech could solve the problem. he sid that he would have to come back with a laptop to get the IP address to change the password code.I have the same problem. not even the phone tech could solve the problem. he sid that he would have to come back with a laptop to get the IP address to change the password code.
First, access your voice mailbox (press VM button & enter your password)
When you hear you have ??? messages, Press 7.
You will be prompted for another password (the Admin default password is 2275)
Press 2 administer mailboxes
Press 1 to reset mailbox password then follow the instructions. It will tell you what the current password is to the mailbox you select and you have the option to keep it or change it.
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done. Your password will be the defaulted to1234.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes, 1 to start recording 3 to accept greeting hang up when done.
As far as the employees voicemail messages, while in the voicemail administration you can reset her password in the "administer mailboxes" prompt which is either 2 or 4 depending on the voicemail type you have. that will reset her password back to 1234.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #.press 1 for the day menu or press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #. press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
hope that helps out
how can i reset the admin password back to 102000 on the norstar t7316
