Nike Cuff Watch WR0094 303 Logo
Posted on Jun 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a Nike Cuff watch, but I can not turn it on! It has two buttons behind but there is no manual saying how turn it on. Would you please help me? Is there any on-line manual for it?
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jun 18, 2011
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291745
Points
7081
Go to http://www.nike.com/timing/ and you will see a small search box labelled "Find manual for your model".
Click on "all models" you can scroll down to find yours.
  • Lyssa Darkko
    Lyssa Darkko Feb 04, 2016
    I know this is five years later, but would u happen to know what brand battery Nike uses with the Cuff watch? I wanna replace it, and the original just now died! Ten years it lasted! It's a cr2016 3v Lithium, but what brand would be best? Thanx!
1helpful
2answers
I have a Nike WC0021 watch and it beeps every hour. How can I turn it off?
Press and hold the top right button for 3 seconds then release - this should turn off the 'chime' function.
1helpful
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
3answers
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
hi,
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
4helpful
I need a replacement strap for my Nike triax 35 watch but all the watch repairers I;ve been to say I need to order one direct from Nike. Can you help? Thanks
Log in to Nike website and click support button. You should be able to ask them how to obtain the part you are after.
3helpful
2answers
Error flashing display, what to do?
You may find solution if you find the link to Nike watch manuals in my tips.
3helpful
2answers
How do i change the time on this watch?
Try to find it here:
Rate, please.
Nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
Top Nike Watches Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a Nike Watch Expert? Answer questions, earn points and help others
