Can't be fuses, as it comes back on!
Questions:-
i) Does it go off when run continuously with volume controls at zero?
(this checks whether the audio output level is causing a problem).
ii) When the unit does operate, is the sound good on both speakers?
iii) Does the fault occur more when outdoors (wind noise tripping the power protection). If so, reduce the low freq EQ setting.
iii) Do the EQ lights flutter when the fault occurs?
This fault has been reported on the Escort 3000 too, see link
Peavey Escort 3000 sound cutting out - Peavey Forum
suggesting this may need a 'electronic modification' to put it right.
Hope this helps.
