Myron & Davis wireless headphones are likely designed to be used as Bluetooth headphones. They can sync or pair with Bluetooth-enabled devices such as smartphones, tablets, computers, or other compatible devices.
To use the headphones, follow these general steps:
Turn on the wireless headphones and put them in pairing mode. This may involve holding down a button or following specific instructions provided in the user manual.
On your Bluetooth-enabled device, enable Bluetooth in the settings and search for nearby devices.
When you see the Myron & Davis headphones appear in the list of available devices, select them to initiate the pairing process.
Once the pairing is successful, you should be able to use the wireless headphones to listen to audio from your connected device.
Keep in mind that the exact pairing process and features may vary depending on the specific model of Myron & Davis wireless headphones you have. If you have the user manual that came with the headphones, it's a good idea to refer to it for detailed instructions. Otherwise, you can try searching online for the manual or contact the manufacturer's customer support for assistance.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
I think what you are asking is how to connect the headphones to the iphone via Bluetooth.
switch on the headphones Bluetooth....go to general settings in iphone ... Switch on iphone Bluetooth....then choose detect devices....when it finds the headphones... Click "pair" ...it will let you know if pairing was successful.once it remembers the device you won't need to do all that again next time you want to use the headphones.now and again you will need to charge the headset up.
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
have your put a new battery in your headphones. they show 10 hours of continuous play so the battery may be charged enough to pair but not to power the headphones. Change the batteries and try it.
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
it won't show in the divice list when its searching
i third this problem!
how do I set up the bluetooth, doesn't want to set up?
