Question about Cell Phones
How do I edit and delete numbers in my phones memory?
  • 223 Answers
As you said me you want to delete some contact from you are phone memory means you can do this if you follow this things.Go to menu select contacts then scroll over to delete option and select that option after selecting that you will get two option telling delete all, one by one.If you select all contact will be deleted if you select one by one means you can delete one by one.If you want to edit the number means you can select menu and then contacts there you will get search select it and type the name after getting the contact select option then scroll over to edit number there you can edit.Thanks for you are question happy to help.
Posted on Jun 17, 2011
    Master:
  • Cell Phones Master
  • 365 Answers
To edit or delete phone number on mobile phone, first connect it to computer via usb cable. Here, you can use an Android data manager tool. With its help, you can easily edit or delete the phone number you want from computer. How to Manage or View Android Contacts on Computer PC
Posted on Sep 25, 2017
    New Friend:
  • 32 Answers
Go to your phonebook
    Genius:
  • 1,127 Answers
Hi
For Edit in no go to the contact open desire contact select option and select edit option, and edit what ever you want to edit,
For Delete the contact go to contact select that contact you want delete and select option there delete two option is showing one delete contact or delete number. if you want delete contact then select delete contact.
Cheer
3 Suggested Answers
SOURCE:
SOURCE: Deleting contacts and numbers
Bring up the listing you want to delete. Click center function key above arrow. This will bring up list. Click down two spaces to delete and then right button to select. This will delete the entire entry. I have found no way to do a group delete.
Posted on May 21, 2007
SOURCE: delete memory/contact numbers from phone
Check settings in user manual...........
Posted on Aug 12, 2012
How do I delete phone numbers from my phone?
      To edit a contact
      1. On Start, tap People .
      2. Flick to All, find and tap the contact you want to edit, then tap Edit .
      3. If this is a linked contact (a contact with multiple accounts that show up as one contact card), tap the account you want to edit (for example, tap Edit Windows Live).
      4. Do one of the following:
      Creating, editing or deleting a contact ' Windows Phone ...
      www.windowsphone.com/.../create-edit-or-delete-a-contact Windows Phone
    Feedback
    how do I simply delete/edit a contact? - Android Phones - Android ...
    www.androidforum.com > Android Forum > Android Phones
Jan 18, 2016 | Cell Phones
Tip
Nokia codes and tricks
Most Popular and Useful Nokia Codes How its done: Go to standby mode (the state where your wallpaper, clock, and operator logo are displayed at the same time - press the red button on your keypad),then press the secret code. Example: if you press Quote: *(asterisk) #(number sign) 0(zero) 6(six)#(number sign) it will show you your phone's IMEI/serial number. The CODES: *#06# - displays the unique serial number or IMEI number *#0000# - shows the firmware or software version details *#2820# - Bluetooth (BT) device address press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs press and hold the MENU button - launch thephone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button. *#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration. *#7370# - reprograms your phone memoryto factory default. all files will be deleted. you will be ask to input your security or lockcode to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead. turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up). *#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
on Jul 10, 2011 | Cell Phones
Delete name and number
Jun 25, 2015 - 10 posts - ‎10 authors
I aparently entered jumbled letters for this and cant delete or edit it. ... activated, I can hold down pressed on the number and 'edit it before calling' , but I still can't figure out how to edit the name or just delete the contact.
How Do I Delete One or More Contacts From My Address ...
https://wiscmail.wisc.edu/.../ab_delete_...
University of Wisconsin?MadisonTo delete one or more contacts from your address book, perform the following ... In
Dec 22, 2015 | Cell Phones
How to delete or edit phone numbers
Go to Phone book on your phone. It will display the Names List/Phone numbers you have saved.
Click on the number you want to edit/delete. Once the name/number is displayed, click on options and then Edit/Delete the Name/Number.
May 06, 2011 | Vacuums
I am using a Nokia C5-00 phone that I got yesterday. Seems like it has the latest software version. But for some reason, it doesnt display the contact name during an incoming call or while listing missed...
This is a very common issue with nokia phones. It occurs mainly when you have stored a particular number with more than one name.
For example if you have a number stored to your sim using one name and you have it stored to your phone memory with another name. In most cases, when you install a new SIM card to a nokia phone, it might copy the contacts from the SIM memory to the phone memory automatically and add some extra information or edit the name automatically. This can cause a conflict between which name the phone should display when any action associated with the number is to be performed. In this case, it displays just the number.
To solve this problem without having to delete any contact, all you need to do is to go to your contact settings and then select which memory should be the default display memory.
Hope this helps you? Please comment for more information and thank you for using FixYa.
Apr 03, 2011 | Nokia C5 Cell Phone
How do you program #'s in to the phone
There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
Jan 23, 2011 | Uniden TRU348 Cordless Phone
I need to know how to take out unwanted phone number and name and program in a new name and phone number. Lost my manual and can't seem to upload yours on my computer.
removing and installing phone numbers isn't hard. Just hold MEM small button down for about 5 seconds then use up or down arrow to arrive at stored number. Then hit select, & follow prompts (edit Memory #, delete Memory #, or go back). The rest you should be able to do.
Aug 27, 2010 | Uniden Cordless Phone exai398i
How can I save numbers to my sim card?
Set your phone to sinchronize your contacts with your PC (if not already set), and sync them. Then, start Outook on your PC, go to the Contacts tab, select the contacts you want to see excluded from your phone's internal memory, and delete them (either go to 'Edit > Delete', or 'Ctrl-D', or simply 'Del'). Now, re-synchronize your phone with your PC. I suppose ActiveSync on your phone will automatically delete the contacts you have excluded from Outlook on your PC.
Hope it works for you.
Cheers! Carlos
Apr 21, 2010 | T-Mobile Wing™ Smartphone
How to format nokia 3310
*(asterisk) #(number sign) 0(zero) 6(six) #(number sign)
The CODES:
press and hold the MENU button - launch the phone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
Apr 16, 2010 | Nokia 3310 Cellular Phone
Deleting protected content
I have a SE K310i. It is the "spiderman3" edition and has a few pictures and a trailer of that movie which are protected( i.e cant be deleted by users like me). delete?
Oct 12, 2007 | Sony Ericsson K310i Cellular Phone
Cell Phones Logo
871 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
