SOURCE: i have oil leaking onto the left side tire of my
Sounds like you have a blown seal on your left gearbox. The only permanent solution is to replace the left brake/motor gearbox assembly. Not exactly a do-it-yourself repair. to verify, you can pull the seat off to inspect with a flashlight or tip the chair up at 45 degrees on the right drive wheel to inspect.
In my experience this is a common problem. It may take some time for enough gearbox grease to ooze out and cause the gearbox to fail. If you run the chair inside the house it will get messy very quickly and the grease stains are difficult to remove. If the chair is upwards of 4 or 5 years consider replacing left and right motor/gearbox assemblies. Hope this helps.
SOURCE: i have an invacare pronto
Leet you have a left motor problem. Usually the motor has to be replaced Sorry Hope this helps
SOURCE: I have an invacare Pronto M51 Surestep power chair
If you have had swing away footrests on this chair you can replace them with model PHW93 and must ask to get them in red when you order them from a wheelchair store. If you dont know where a store is that sells Invacare products, call Invacare customer service at 800-333-6900.
SOURCE: The invacare tilt wheel chair will not stay in
The release cable for the back is preventing the cylinder from locking. Adjust the cable just like you would adjust a bicycle hand brake. Adjust the cable so there is a quarter inch of play in the release lever. Look along the cable for a adjustment section.
