Posted on Jun 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp deskjet 948c. What Do The Button's Do
Anonymous
Level 2:
Novelist:
  • Expert 111 Answers
  • Posted on Jun 17, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
111
Questions
0
Helped
45089
Points
258
Buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
hp deskjet 948c.  What Do The Button's Do - sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on inkhp deskjet 948c. What Do The Button's Do - sayurisan20_35.jpgstalled.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. Whehp deskjet 948c. What Do The Button's Do - sayurisan20_36.jpgixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
My ipod bluetooth is on but I can not get my Sx-948c headphones to wireless connect.
YOU HAVE TO POWER ON YOU HEADPHONES , THEN SEARCH FOR IT IN YOUR IPOD THEN CONNECT ,
HP Deskjet D2560
First step is to see will if it print a test page.
Go to Start, settings, printers. Right click on the printer, properties, print test page.If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
Try the self-test? I'm not sure on the 5550 printer, but do this:With the printer ON,
1. Press and hold the power button
2. While holding the power button, press the resume button 4 times
3. Release the power button
2answers
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
HOW CAN I DOWNLOAD DESKJET PRINTER SERIES 1500 COPY I
I'm not sure that you mean the HP Deskjet D1500 series. In case this is correct there is no 1500 series. Follow the proper links for your product:
* HP Deskjet D1520 Printer
* HP Deskjet D1530 Printer
* HP Deskjet D1550 Printer
* HP Deskjet D1558 Printer
* HP Deskjet D1560 Printer
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
My hp deskjet f380 is not scanning.
To scan, you need the HP Photosmart software installed (you can download it from HP at the link below). Start HP Photosmart, then put your original in the scanner and press the "Scan" button. You can scan multiple sheets, when you're done, click "done" and the files will be saved as JPEGs in the My Scans folder in My Documents.
4helpful
Orange ink light keeps flashing and printer won't print
hello,
To correct this problem, unlock the carriage from the printer‘s capping station.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
  8. The printer should print the alignment page.
  9. Print from another application.
    thank u
2answers
Cannot scan with hp deskjet f4185 because....
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3177566&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB - here u can find the software
If helped rate fixya
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
