SOURCE: amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
SOURCE: pyramid arctic 4ch amp pb1617x goes right to
pull out 1 rca jack at a time and try it..usually speaker wires touching...or blown speaker
SOURCE: Need advice on setting up amp with my two speakers.
This is hard to explain and what needs to be done is wire in parallel both subwoofers. This website will help just put in the amount of speakers and amount of ohms each and it gives you diagram.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=81#results
SOURCE: i have a pyramid amp
