Question about Kirby Ultimate G Bagged Upright Vacuum
Ok, my kirby just stopped working. I had someone helping with my vacuuming, so maybe they ran over the cord or something. I can see a recent scuff mark on the cord.??? Also last time I pulled the front part off (unlocking the belt etc..) I noticed that the metal thing that pokes out had a 'cloth type' covering on the end of it, i presumed that it was there to protect the belt when being driven??? However when checking the vacuum for possible reasons to why it had just stopped working, I now notice the the 'cloth' protection thing on the end of the metal rod is now not there???? Can you please enlighten me to both mistries. thanks
    New Friend:
  • 4 Answers
When was your Kirby made? If you have an older Kirby, inside where the motor lies is a single or double magnet with a spring coil attached to it. Within that coil is a filament wire held together with a shiny disk at other end. This filament does go bad from time to time and needs to be replaced. This usually is not a do it yourself job. If you can find the proper filament, you might but usually there are several types and sizes, let your local distributor change it for you.
Posted on Apr 11, 2017
6ya staff
SOURCE:
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Posted on Oct 25, 2007
Anonymous
  • 146 Answers
SOURCE: Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Posted on Nov 09, 2007
Uplate
  • 112 Answers
SOURCE: Kirby G5 Vacuum power switch problems
try this online guide to replacing the powerswitch..
Hope this helps
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Posted on Jan 10, 2008
Anonymous
SOURCE: Kirby Sentria
Ha.. Im so stupid! The vacuum was in drive causing the wheels to turn when moving backwards thus leaving scuff marks
(from the rubber wheels) on the hardwood. Place the Vacuum in Neutral and turn the belt off and Voila, No more scuff marks! Thanks for all the suggestions!!! You all are GREAT!!!
Posted on Mar 22, 2008
Anonymous
  • 120 Answers
SOURCE: KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Posted on Sep 26, 2008
I accidentally ran over the cord and then machine motor slowed down and stopped running. It wouldn't turn back on
get a new cord. It was stretched and ripped apart under the outer rubber cords housing insulation
Sep 01, 2010 | Kirby G4 Bagged Upright Vacuum
How do I change the electric cord on my Kirby vacuum?
Hello, youngh
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Jul 01, 2010 | Kirby G4 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
How to dissasmble vacuum cleaner, kirby g4 to check if motor or switch is bad
before you do all this, check the cord where it mounts to the handle up top by the pivoting strain relief. Frequently the cord goes bad right where it snaps in the strain relief.
first you will need to remove the handle, bag, and the cord. there is a release button for the handle, the mini emptor on the bottom of the bag twists off away from the body. there should be 2 screws on the scuff plate, one to hold the cord strain relief and another down by the transmission for the scuff plate. use a small flathead screw driver in the slot of the scuff plate and pry up. it will pop off. you should also take out the screw in the cord cover where it plugs, pop the cover off and remove the cord. now you can remove the top cover. there will be 2 screws in the front of the unit, and 2 screws under the scuff plate. they are either phillips or T15,T20 torx. remove those 4 screws and you can lift the top cover off and access the motor and the switch. check for bad motor carbon brushes and a worn commotator where the brushes ride. let me know if you need anything else.
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Does the kirby G5 have a reset button? If so,
No reset button. It sounds like you might have one of several possible problems. Some ideas I have that you could try yourself would be to check the lockout switches: there is one behind the head nozzle, maybe the nozzle is on crooked, if so, maybe not engaging the safety switch, the other lock-out is located where the bag screws on, unlock the bag and re lock it to ensure proper fit. Otherwise, take it to the shop because it could be the motor, the cord, the switch. Hope this helped ya. Let me know. Thanks, Rene (the Vacuum Doctor)
Nov 11, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby stopped working
Here is a guide to diagnosing a problem with your Kirby. I would imagine that your power cord has a short in it or the carbon brushes need replaced. You may want the take a look at my guide for replacing the power switch as well to make sure that it was hooked back up correctly.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps...
Marci
Jun 15, 2009 | Kirby G4 Bagged Upright Vacuum
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuum stopped working
Sometimes after years of use the power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the switch may be bad or the motor needs to be serviced. Good luck. Please rate me so I know if I helped.
Dec 30, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Sentria
Do the rear drive wheels have the rubber on them or are they worn off and it is just plastic now.
Mar 18, 2008 | Vacuums
Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
251 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
