Pride Jazzy Select 6 Indoor Power Wheelchair Logo
Anonymous Posted on Jun 16, 2011
I have a Jazzy 1121 wheelchair and need a face plate for the controller. The ss# is J40355044020. Where can I find one?
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Jun 17, 2011
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288568
Points
1801
Contact Pride Mobility @ 1800-800-8586 ask for Jazzy tech support and ask if you can order a faceplate for your joystick Hope this helps you
mark brown
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Oct 05, 2012
mark brown
Contributor
Level 1:
Welcome Back:
Answers
6
Questions
5
Helped
3686
Points
9
If no joy with pride just search google for "
Keypad for 6 Key VSI Joystick Controller"
I have a jazzy 1121 and my seat moves around a little bit. How can I lock it?
Pride Mobility Jazzy 1121 - USA TechGuide
www.usatechguide.org/itemreview.php?itemid=570
19 posts - ‎16 authors Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
1helpful
Jazzy power chair's battery runs out quickly afert being fully charged
I had the same problem I had to replace the batteries problem solved.But the batteries are not cheap
Have a jazzy I bought from a cousin , its a jazzy jet 2 from the year 2000 need help to get manual ,where can i find it
log onto pridemobility.com and select jazzy then select user manuals then look under discontinued models and find Jet 2 you should be able to download the manual Hope this helps
My jazzy 1121 is not charging. I plugged it in last Wednesday and have checked several times. It has not charged.
candy probably a battery issue but it could also be a charger problem also If the batteries had gotten really low then the charger is not designed to pickup really low voltages. If possible have your provider (Where you got the chair) check the batteries and charger for you Hope this helps
1helpful
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
1helpful
2answers
I have a fairly old 1121 but cannot find any levers to go into freewheel. I have seen a modern one and can see them in that. Can you help?
Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
1 red and 3 amber lights flashing after stopping and goes around in circle on a jazzy 1121 powerchair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
7helpful
3answers
Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
